SignalExpress
Digital input and counter simultaneously on NI USB-6259
Hi
I'm using SignalExpress 2012 and a NI USB-6259 board to measure the function of 4 relays.
The test procedure i very long and the operation of the relays occurs more or less periodically.
I'm having trouble measuring the relays using digital input and counting the operations of relay no. 1 simultaneously.
My setup is as follows (see also the attached project file)
  1. DAQmx Generate - Generate clock for the digital inputs measurement
    - Pulse output: Dev1_ctr0  (Dev1 is the USB-6259 on my system)
    - Generation Mode: N Pulses
    - Samples to Write: 100
    - Output Terminal: PFI12
    - Trigger Source: PFI0 (Relay no. 1 connected here to act as the trigger since it always operates whenever one of the other relays operates)
    - Timeout: -1 (run until stopped)
  2. DAQmx Acquire - Measure relays digitally
    - Digital Input: Dev1_port0_line0, Dev1_port0_line1, Dev1_port0_line2, Dev1_port0_line3 (Relay no. 1, 2, 3 and 4)
    - Acquisition Mode: N Samples
    - Samples to Read: 100  (to match the 100 samples generated by the step above)
    - Triggering: None
    - Advanced Timing
        - Sample Clock Type: External
        - Clock Source: PFI11 (the clock output generated at PFI12 by the step above is connected to this input)
        - Timeout: -1
  3. DAQmx Acquire - Count number of operations on relay no. 1
    - Edge Count: Dev1_ctr1 (Relay no. 1 i also connected to this input.)
    - Acquisition Mode: 1 Sample (On Demand)
Using only step 1 and 2 everything works perfectly. But when I add the 3rd step I get an error (no. 50103) saying that two resources can't use the same device simultaneously, see attached picture.
Any input on this is much appreaciated!
Joacim
Message 1 of 1
(5,730 Views)
