07-29-2015 10:38 AM
I am trying to understand the time of my data file I've exported from signal express. If I'm using continuous samples with the rate at 330m and the samples to read set for 1, what is the time difference in data points? I initially thought it would give me data samples roughly every 3 seconds, but there are so many data points I think it's capturing much faster.
07-29-2015 03:10 PM
What hardware/modules are you using.
Some modules have a minimum sample rate.
See this post
http://forums.ni.com/t5/SignalExpress/Slow-Log-Rate-Needed-using-cDAQ-9174/td-p/3163388
07-29-2015 03:25 PM
07-29-2015 03:57 PM
If you want 3s/s try setting your Hz to 3 and sampes to read to 3.
Assuming the device will sample that low.
