09-04-2008 05:32 AM
Hi
When I try to start my Signal Express 3.0, the splash screen just apere for a second then windows will stopp it.
I´m using Vista 32bit
Solved! Go to Solution.
09-04-2008 08:43 AM
My first suggestion would be to try doing a "Repair" on the SignalExpress installation; under Start >> Control Panel >> Programs and Features >> National Instruments Software, select NI LabVIEW SignalExpress 3.0 and press the Repair button.
If that does not work, perhaps you could tell me some of the following:
1. Did you upgrade SignalExpress from a previous version?
2. Did you only install SignalExpress recently, or also other NI software?
Phil
09-04-2008 08:52 AM
09-16-2008 06:12 AM
09-19-2008 06:05 PM
Hi Aland,
Great to know that you got it to work. However, SignalExpress will work without disabling UAC. We specifically test for it and there are numerous users who have been working with SignalExpress since release with UAC enabled. There could be something else that's causing this problem. The above mentioned questions might help us find the cause. It definitely would be great if we could continue this conversation. Thank you.
10-23-2008 05:01 AM
05-19-2009 05:53 AM - edited 05-19-2009 05:54 AM
I have same problem, for over a year it was working fine, now just crashng at start-up. I'm using Windows XP SP3. The error sound like this:
"LabVIEW SignalExpress has encountered a problem and needs to close. We are sorry for the inconvenience."
error signature:
AppName: signalexpress.exe AppVer: 3.0.0.3000 ModName: kernel32.dll
ModVer: 5.1.2600.5781 Offset: 00012afb
LOCALS~1\Temp\NI_ERRORLOG.TXT caused an Unknown exception type (0xe0434f4d)
in module kernel32.dll at 001b:7c812afb.
Exception handler called in Unhandled exception.
C:\Program Files\National Instruments\SignalExpress\SignalExpress.exe
Operating system: Windows XP (5.1.2600).
2 processor(s), type 586.
30% memory in use.
Context:
EDI: 0x00204a10 ESI: 0x09e0e8a4 EAX: 0x09e0e818
EBX: 0xe0434f4d ECX: 0x00000000 EDX: 0x0000012f
EIP: 0x7c812afb EBP: 0x09e0e868 SegCs: 0x0000001b
EFlags: 0x00000202 ESP: 0x09e0e814 SegSs: 0x00000023
Bytes at CS:EIP:
5e c9 c2 10 00 85 ff 0f 8e 36 93 ff ff 8b 55 fc
Module 1
Image Base: 0x00400000 Image Size: 0x00087000
Checksum: 0x000737b3 Time Stamp: 0x48480af3
File Size: 536576 File Time: 6/5/2008 11:07:20
Version Information:
Company: National Instruments
Product: LabVIEW SignalExpress
FileDesc: LabVIEW SignalExpress
FileVer: 3.0.0.3000
ProdVer: 3.0.0.3000
I tried to repair still the same problem, i also restored m computer toan earlier restore pont, still the same problem...
05-19-2009 06:18 AM - edited 05-19-2009 06:18 AM
05-19-2009 07:37 AM
Now, not even Measurement & Automation explorer doesn't work... same error, crashing at start
05-20-2009 07:07 AM
