NI Home
Cart Cart | Help
Hello Events Academic NI Developer Zone Support Solutions Products & Services Contact NI MyNI
You are here:
NI Home > NI Developer Zone > NI Discussion Forums
Reply
Member
AkshayHari
Clipping Signal
Is it possible to clip a signal at a certain threshold value in SignalExpress? I have about 30 seconds of data that I would like to clip at mean plus-or-minus two standard deviations.
Akshay
Member
Eric_NI
Re: Clipping Signal
Hello AkshayHari,
Look for the Limiter.vi in the SignalExpress\Examples\Tutorial directory. The Limiter VI accepts a time-domain waveform as an input, clips the signal above and below values that you specify in the Step Setupdialog box, and returns the clipped waveform as an output signal.
Eric  NI
Member
AkshayHari
Re: Clipping Signal
[ Edited ]
Thanks for your help!
How exactly do I add that VI to my project?
-Akshay
Member
Eric_NI
Re: Clipping Signal
Hello AkshayHari,
If you mean to add a VI to your NI Signal Express project, you need to right click the Project area, then "Run LabVIEW VI" and select the LabVIEW version of your VI and browse to it.
Eric NI
Member
AkshayHari
Re: Clipping Signal
Hi Eric,
I tried the "Run LabView VI" option, but kept getting an error message saying "Please Select a VI to Open" even after selecting the VI that I wanted to open.
Akshay
Member
Eric_NI
Re: Clipping Signal
Hello AkshayHari, is the VI compatible with the version of LabVIEW you select?
Member
AkshayHari
Re: Clipping Signal
I tried all the versions of LabView that were shown as options.
Akshay
Member
Eric_NI
Re: Clipping Signal
Hello Akshay,
Take a look at the following KB, it gives you some steps to have a VI working in SignalExpress
http://digital.ni.com/public.nsf/allkb/359D14941D6936E98625729D008387D5
Eric NI
By using this web site, you accept the Terms of Use for this web site. Please read these Terms of Use carefully before using any part of this site. Please go here for information on ni.com's copyright infringement policy.
My Profile | Privacy | Legal | Contact NI © 2011 National Instruments Corporation. All rights reserved.    |    E-Mail this Page E-Mail this Page
