03-20-2009 04:18 AM
Hi guys,
I'm new here and just have browsed some of the related topics here regarding my problem but could not seem to find anything to help me fix this problem so I decided to post this. I currently have a saved waveform from an oscilloscope that is quite big in size(around 700MB, CSV file format) and I want to view this on my PC using SignalExpress. Unfortunately when I try to load the file using "Load/Save Signals -> Load From ASCII", I always get the "Not enough memory to complete this operation" error. How can we view and analyze large waveform files in SignalExpress? Is there a workaround on this?
Louie
P.S.>I'm very new to Signal Express and haven't modified any settings on it.
03-23-2009 10:02 PM
Hello Louie,
May I know what version of SignalExpress are you using? Also, how much physical RAM is installed in your PC?
The problem you are facing could because there is not a sufficiently large block of RAM to hold the large saved waveform. A possible solution is to tweak your virtual memory settings. Have you taken a look at this link yet? While it is titled for LabVIEW, it is also relevant for SignalExpress.
Victor
NI ASEAN
03-24-2009 12:50 AM
lhaoxian wrote:Hello Louie,
Victor
NI ASEAN
The version is 2.5.1, RAM=2GB. I will try to implement the suggested ways on the link and will update this thread on the results. Thanks a lot.
03-24-2009 08:38 PM
03-25-2009 11:33 PM
Hi Louie,
Are you encountering a read-only message when you tried to save the boot.ini file? If so, you can try this method: right-click on My Computer >> Select "Properties", and go to the "Advanced" tab. Select "Settings", and on the next screen, there is a button called Edit. If you click on Edit you should be able to modify the "/3GB" tag in boot.ini. Are you able to change it in this manner? After reboot, you can reload the file to see if it helps.
To open a file in SignalExpress, a contiguous chunk of memory is required. If SignalExpress cannot find a contiguous memory chunk that is large enough to hold this file, then an error will be generated. This can happen when fragmentation occurs in memory, and fragmentation (memory management) is managed by Windows, so unfortunately this is a limitation that we have.
As an alternative, have you looked at NI DIAdem before? It is a software tool that allows users to manage and analyze large volumes of data, and has some unique memory management method that lets it open and work on large amounts of data. There is an evaluation version which is available for download; you can try it out and see if it is suitable for your application.
Victor
NI ASEAN
03-25-2009 11:54 PM
I was able to change the boot.ini but our security software seems to prevent the computer from booting up when I added "/3GB". I'll try to check out Diadem.
Thank you,
Louie
