SignalExpress
Cannot Datalog Frequency (counter) Data in SignalExpress 2014
I am attempting to acquire data from a PXI-6143 card using SignalExpress 2014. I am acquiring frequency measurements from one of the onboard counters. However, SignalExpress does not show this counter input as available for datalogging. See the attached picture for my setup:
Under the "Recording Options" tab it says "No signals available to log". Any ideas what I've done wrong?
(4,842 Views)
Accepted by topic author shansen1
Change your acquisition mode to 1 sample on demand and set your sample period in seconds.
I think SE doesnt like continuous samples when working with frequency
SCXI- 1000 Chassis w/ 1346 adapter
PCI 6281 DAQ card
SCXI- 1520 Bridge Board w/ 1314 Terminal Block (x2)
SCXI- 1180 Feedthrough Panel w/ 1302 Block
Signal Express 2014.
Win7 Enterprise
(4,752 Views)
OKors: Thanks, that change does make it possible for me to record the signal. Unfortunately, now that I'm sampling single data points SignalExpress won't let me use any of the frequency analysis tools during the recording or after the fact. Is there any way around this?
(4,746 Views)
