11-13-2009 09:12 AM
I've recorded a lot of acceleration signals (with their spectrum) in SE 3.0.
When I'm trying to load the data from the protocols, I'm only able to load the raw data although the spectrums are displayed in the protocol tree too.
When I'm using the export functionality (Ascii/excel) only the header is exported...
When I'using the import tdms file option, a log is imported but contains no data or name.
The tdms file is about 1,6 MB and could be opened in labview 8.6 without any problem... the spectrum data could be read.
How could this bug be fixed?
Karsten
11-13-2009 09:37 AM
when I'm opening my spectrum-tdms file with labview, I'm only able to read one of my four channels - and I don't know which...
when I'm opening my acceleration-tdms file I see all channels...
11-17-2009 06:33 AM
Hi pho_nox,
can you please attach your SE project?
So maybe I can reproduce this here.
11-18-2009 02:27 AM
I attached the project.
11-18-2009 03:51 AM
Hi Pho_nox,
everything seems to work fine here with your project.
I can see the curves in the data view in SE and attached you can see the exported files.
But I used SE 3.5 (2009)
Maybe you can try the latest version of SE too in evaluation mode and try if you see a different behaviour then.
You can download the evaluation version here:
http://joule.ni.com/nidu/cds/view/p/id/1378/lang/de
11-18-2009 03:51 AM
