01-31-2016 10:02 AM
Hello All,
I'm trying to acquire the logic probe of my oscilloscope (MSO2024) with Signal Express 2.5.
Once the oscilloscope is recognized, I'm only able to select the 4 channels analog probes but not the d0-d15 logical probe.
Is it possible to measure also d0 - d15 or not?
Thank you for any help in advance.
02-01-2016 05:25 AM
you could try updating your drivers. Check in the following link:
Despite this, I'm not sure you'll be able to measure also digital ports.
Good luck!
Bye
02-01-2016 05:42 AM
Hi, thank you but the link doesn't work..
Where can I find this driver?
Do you mean the driver of the MSO ?
02-01-2016 07:26 AM
Yes, I was thinking about that.
I think the problem is with the Tektronik instrument and its communication with NI software, you could try to update the VISA driver, but I'm not sure you solve your problem, but I hope so.
Bye
02-05-2016 10:57 AM
