01-29-2017 05:43 AM
How Can I calculate mean value form limit test passed signal? Static step gives on NaN.
Thanks in advance
Mika
Solved! Go to Solution.
01-30-2017 10:16 AM
Hey Mika,
It looks like you're getting the NaN as it's including the data at 0-325ms and 675-1000ms. I'd look into changing the acquistion of your data to only include the actual data.
Limit Tests in Signal Express Help Page: http://zone.ni.com/reference/en-XX/help/371268J-01/expresswb/limit_test/
If not feel free to post your code to see if this helps shed any light?!
Kind regards,
Rebecca
01-31-2017 06:26 AM
Hey Rebecca,
I was not so precise what I am doing. I hope attached file explain.
-Mika
02-01-2017 06:48 AM - edited 02-01-2017 06:49 AM
Hey Mika,
I don't have the actual data you'd be looking at (i.e a TDMS file) but I've had a quick look at the steps.
Try inserting a subset step before your statistics to find the mean and specifying the range of 325m - 675m (although these numbers are rough estimates from looking at your intial posted image so may need amending to ensure there is no NaN data). Then select the new subsection as the signal to use in the statistics step instead.
Hope this helps.
Rebecca
