01-26-2015 04:00 PM
Can I generate a hardware timed, 100 Hz square wave with a USB 6001 or 6002?
01-27-2015 01:26 PM
Hello salty,
The specification document for both devices (found at the links below) indicates that hardware timed analog output is possible on both devices.
SPECIFICATIONS NI USB-6001:
http://www.ni.com/pdf/manuals/374369a.pdf
SPECIFICATIONS NI USB-6002:
http://www.ni.com/pdf/manuals/374371a.pdf
Each device supports a maximum update rate of 5 kS/s simultaneous per channel, hardware timed. Therefore, you should be able to generate a hardware timed 100 Hz square wave using either device using an analog output task.
J_Bou
01-27-2015 03:59 PM
Thanks J_Bou,
Thanks for the information and the confirmation. I was able to use one of the examples to produce the square wave.
04-13-2015 06:14 AM
04-13-2015 12:01 PM
I tried to generate a 5 kHz signal but was only able to generate up to 2.5 kHz.
04-14-2015 12:31 AM
Hi, you used a Square Waveform VI or something else?
04-16-2015 11:11 AM
I used the analog output of the 6001 to generate the square wave. I used the Voltage - Continuous Output.vi from the provided examples.
04-16-2015 03:30 PM
Thanks!
07-26-2021 02:07 PM
Did the voltage-continuous. vi examples work for you using NI-DAQ USB 6001 ?
Because for me it is not working, and then when I checked the requirements to run that circuit, nowhere it was mentioned about USB-6001
Could you please send me your vi file or help me with it?
I am fairly new to LabView and NI-DAQ.
Devansh
04-05-2023 01:15 PM
It works fine if you set it to work within the constraints of the USB-6001. The sample rate for the USB-6001 is limited to 5kHz and the frequency output for the selected analog output must always be equal to or less than half the sample rate.
