07-31-2015 04:41 PM
I am looking for example C code (using NI-FGEN function calls) that shows how to work with multiple PXI-5412 contained in one chassis. I've been going through the NI-FGEN examples, but haven't found an one that covers this topic.
I have a PXI-1036 chassis, a PXI-8360 MXI express card, and 4 PXI-5412 cards (each has a single channel). What I am looking to do is create a single application that set these cards, loads in waveform data from file to each, and then generates output from all the cards simultaneously.
I am familiar with the NI-FGEN ArbitraryWaveform example, and have used that as a starting point for my application.
08-03-2015 08:10 AM
What you are trying to do, in escence, is program all four signal generators independently, and then start them at once.
