01-29-2012 07:27 AM
I have two daisy chained NI PXIe 5673. But for the meantime, I only have to transmit one RF signal at 915 MHz. What is the correct clock source for this setting? Thank you.
01-30-2012 07:21 PM
Hey Margarette,
The onboard clock should work for your settings.
The steps for how to configure the internal clock for the 5673 can be found here.
Just in case you want to use the external clock, it's configuration can be located here.
Jake Glascock
Applications Engineering
