Signal Generators
how to generate 2 rectangular signals with pxi 6221
Hi everyone,
 following problem. I try to generate two rectangular signals with adjustable frequencies. The first one is working fine, but when creating the second signal, I get following error:
DAQmx Write (Digital 1D U8 1Chan NSamp).vi:2410002<append>
<B>Property: </B>SampClk.Src
<B>Property: </B>SampClk.ActiveEdge
<B>Source Device: </B>Dev6
<B>Source Terminal: </B>Ctr1InternalOutput
<B>Required Resources in Use by</B>
<B>Task Name: </B>_unnamedTask<1>
<B>Source Terminal: </B>Ctr0InternalOutput
<B>Destination Device: </B>Dev6
<B>Destination Terminal: </B>do/SampleClock
<B>Task Name: </B>_unnamedTask<3>
How can I fix this problem? Or do you have other ideas to realize this example?
VI is included.
Kind regards
Jens
(4,921 Views)
 No ideas?
(4,891 Views)
Hi everyone,
I found my solution. I used two counters to create those pulse signals and to adjust the frequency.
Here is my solution, it works fine for me.
(4,885 Views)
