03-04-2015 07:12 AM
I simulated a 5412 AWG by using the string "Simulate=1,DriverSetup=Model:5412;BoardType:PXI;MemorySize:268435456" as the option string on niFgen Configure Output Mode. I then created and ran the simulated device, apparently sucessfully. But how do I view the output (ch0) of the simulated device?
03-04-2015 09:51 AM
You can't, since the device isn't real.
03-04-2015 12:55 PM
OK
I can also create FGEN Soft Front Panel via Measurement and Automation Explorer, which does display the simulated 5412 output, but I guess what you are saying is there is no way to connect this simulation with the Labview software simulation.
