NI Home
Cart Cart | Help
You are here:
Reply
Active Participant
Henrik_Volkers
Accepted Solution
Sync pulse on 5422 in Standard Mode How?
[ Edited ]
For a trigger  I want to output a Sync pulse on every periode (to PFI0 AND PXITrigX) on a 5422 FGEN  in Standard Mode.
I can do it in AWG Mode, but how to do it in Standard mode?
Greetings from Germany
Henrik
LV since v3.1
Active Participant
Henrik_Volkers
Re: Sync pulse on 5422 in Standard Mode How?
Found this community example that solved the task :smileyhappy:
Didn't know that the marker events also work in standard mode...
Henrik
LV since v3.1
Member
kirsch
The example is using Data Marker Events. This is different than the Marker Events associated with Arb Waveform Mode. What the Data Marker Event feature does is, essentially, route out up to four distinct bits from the waveform data being fed into the main DAC on the 5422.
If you want the absolute best possible jitter performance on the sync pulse, then you'd be better off with one of our dedicated Function Generators, like the 5402 and 5406, which use a calibrated hardware comparator in order to create the sync pulse.
Good luck!
Marcos Kirsch
Senior Software Engineer
Core Modular Instruments Software
My Profile | Privacy | Legal | Contact NI © 2011 National Instruments Corporation. All rights reserved.    |    E-Mail this Page E-Mail this Page
