NI Home
Cart Cart | Help
Hello Events Academic NI Developer Zone Support Solutions Products & Services Contact NI MyNI
You are here:
NI Home > NI Developer Zone > NI Discussion Forums
Reply
Member
ajax48
Accepted Solution
PXI-5441 vs. PXI-5421
Does anyone knows if the PXI-5441 can be ordered with LVDS output option?
In the datasheet is stated, that a similar, simpler PXI-5421 can generate low-voltage-diff-signal, too (not only the analog single ended).
Member
kirsch
Re: PXI-5441 vs. PXI-5421
The NI 5441 cannot be ordered with LVDS. I'm not sure why you want to use the LVDS connector, but if you simply need a few bits that are embedded in your waveform data to be output as digital signals, you can route specific bits (up to four) to any PXI trigger line or the two front panel digital connectors (TTL).
Marcos Kirsch
Senior Software Engineer
Core Modular Instruments Software
Member
kirsch
My bad ajax48... the 5441 does indeed come with the LVDS connector as can be seen in the picture. Sorry about the confusion. The comment about routing out individual data bits stands.
Marcos
Marcos Kirsch
Member
ajax48
Hi  kirsch,
Thanks for your reply.
So, the front connector on the PXI-5441 (and on PXI-5421) is the input/output for digital signals? And the mentioned “option” is just buying an additional cable(s) and interface board (brake-out board)?
May you assure me that all dedicated (configured) digital signals (so – LVDS – low voltage differential signals) can be accessed from this front-connector?
BTW. The reason I’ve asked for LVDS is very simple. Almost all high speed chips I work on have differential inputs and outputs only (not single ended). For testing I need to generate “real” differential signals – at least voltage levels should be OK (in the test mode, signals don’t need to be switched with the target high frequency).
Member
ajax48
Hi Marcos. In the last post I’ve used your nickname not starting with capital “K”. I’m sorry. A moment after sending, I realized that it is your last name, too.
Active Participant
[ Edited ]
All NI PXI-5441 modules come with the DDC connector, and for your future reference all memory options except the 8MB option for the NI PXI-5422/21 will come with the DDC as well. A pin out for the DDC can be found here http://zone.ni.com/reference/en-XX/help/370524M-01/siggenhelp/5441_ni_5421_digital_connector/
JaceD
Signal Sources Product Support Engineer
Member
ajax48
Thanks a lot! I've closed the issue.
By using this web site, you accept the Terms of Use for this web site. Please read these Terms of Use carefully before using any part of this site. Please go here for information on ni.com's copyright infringement policy.
My Profile | Privacy | Legal | Contact NI © 2011 National Instruments Corporation. All rights reserved.    |    E-Mail this Page E-Mail this Page
