I have a very simple and basic question. I am trying to multiply a constant value to an analog signal generated from a sine wave block. Whereas, the Multiplication block only accept fixed point values. How can I do that. plz help.
How are you generating the signal? What VI are you using?. The figure shows what I understood from your post but I didn't have any error, let me know if this is not what you needed.
SindhuVelayudham - This should be the same code Diego_Sanchez posted, except with an analog signal and square wave signal as inputs to the multiplier. You can generate a square wave signal by either using the a function from the Waveform pallette (e.g. Waveform Analog Wfm -> Generation -> Square Wfm) or just using the Simluate Signal Express VI.
