04-15-2016 02:03 PM
I am trying to generate some modulated signal from the PXI5646R SG by using C++ code.
In order to have modulated signal, a IQ file (txt or tdms) should be loaded first. I would like to know what command I should use to load the IQ files in C++. Or is there any specific way that generates the modulated signal?
I checked the niRFSG.h, can not really find a command that works.
Thank you,
Neo
04-18-2016 03:45 PM
Hi Neo,
Have you looked into the niRFSG_WriteArbWaveform function? This function takes I and Q data as parameters and will write the waveform to the NI-RFSG device.
If your IQ file is in the TDMS format, the links below may be helpful in determining how to read this file to extract the I and Q data to be used with this function.
How Do I Read or Write to a TDMS File Using Third Party Software?
04-22-2016 09:30 PM
Hello, Julia,
We tried to read the TDMS file by following an example in NI(The NI TDMS File Format). It does not work, always retruns "unexpected error".
We found a command to upload the IQ file in SG and generate the modulated signal.
It requires to install NI-RFSG Playback Library.
Ne0
