NI Home
Cart Cart | Help
You are here:
Reply
Active Participant
snowpunter
Immediately trigger to next waveform on 5673 even when in the middle of generating a waveform
[ Edited ]
I'm using the following script with a 5673:
script finiteGeneration
 repeat forever
  repeat until scriptTrigger0
   generate noise
  end repeat
  clear scriptTrigger0
  generate waveform
 end repeat
end script
My intent is generate a noise waveform until a trigger arrives on the PXI backplane, immediately switch to waveform and then generate noise until the next trigger. I recall using a property node with the underlying FGEN driver that would enable moving to the next waveform immediately when the trigger was received, instead of waiting until the current waveform has finished generating and then moving to the next waveform.
The FGEN help didn't appear to note that any of the four triggering options have this feature enabled... was this something that was disabled in a later release of the driver?
CTA, CLD, MTFBWY
Active Participant
Paul_C.
Re: Immediately trigger to next waveform on 5673 even when in the middle of generating a waveform
Hello Snowpunter,
The following changes to your script should do the trick.
repeat forever
break on scriptTrigger0
repeat forever
generate noise
end repeat
end break
generate waveform
end repeat
end script
The break should exit out of everything immediately.  I haven't set this up yet to double check, so let me know if it doesn't work and I will try it out on my end.
Hope this helps,
Paul C.
Applications Engineer
Active Participant
snowpunter
They haven't kicked you off the second floor yet Paul?
:smileywink:
CTA, CLD, MTFBWY
Active Participant
Paul_C.
They moved me to the basement now... but I got to keep my stapler. :smileyvery-happy:
Paul C.
Active Participant
snowpunter
Well, tell them to add 'break' to the documentation so I don't have to look like an incompentent customer on the forums :robotmad:
CTA, CLD, MTFBWY
Active Participant
snowpunter
[ Edited ]
Its buried in the Script Editor Help, but not in the RF Signal Generator Help for those looking.
CTA, CLD, MTFBWY
My Profile | Privacy | Legal | Contact NI © 2011 National Instruments Corporation. All rights reserved.    |    E-Mail this Page E-Mail this Page
