06-16-2014 11:30 AM
I am generating a pulse signal with PXI 5412 and I'm willing to send a trigger from PFI 0 line on the front panel, then use this signal to trigger a digitizer in another computer for data acquisition. Seems I need to generate a marker event then export this marker event to PFI 0 line, but I don't know how to generate this marker event... I attached my VI here, if anyone has some suggestions that will be great... Thanks in advance!!!
cbing
06-17-2014 08:54 AM
cbing8859,
Thanks for the post. You are correct that what you need is to create and export a marker. During configuration of the FGEN settings, you can use a property node to specify Active Channel, Marker Position, Marker Event Output Terminal, and Marker Even Output Behavior. Please refer to the shipping examples, specifically Help >> Find Examples >> Harware Input and Output >> Modular Instruments >> NI-FGEN >> Arbitrary Waveform Generation >> Fgen Arb Waveform Marker.vi
Post back if you have any questions regarding the example.
Mark B.
06-17-2014 09:28 AM
Hi Mark,
Thanks for the reply. Actually I solved the problem last night through NI tech support. I checked the example you provided, the thing is in that example the output mode is Arbitrary Waveform, in my case, however, I use arbitrary sequence in order to send a pusle signal. The question at that time is whether I can send out a marker under arbitrary sequence mode. The NI tech offer me the Fgen Adv Arb Sequence.vi which can set a marker position and generate a marker for the output event, so I finally solve the problem. Pretty excited though.
Again, thanks for posting solutions for my question, I appreciate it!
cbing
