07-09-2009 04:03 AM
I have the .lib file for my lock in amplifier. The lib file is written for labView and already contains visual interface (like ActiveX ). The point is that I need this file for programming in CVI (8.5). How can I convert .lib from LabView to CVI?
Thank you .
Denis.
07-10-2009 02:04 PM
07-12-2009 07:46 AM
The thing is that the only thing I have is the .lib file with the ReadMe.txt:
".....The file SR72XXLV8.zip is a WinZip file conataining a LabVIEW 8.2 library file,
SR72XXLV8.llb, containing VI's to access virtually all of the instrument's
controls and outputs......"
When I insert the lib file into the CVI, it can do nothing with it. When I try to open it, the "Cannot open binary files as text files" message appears.
07-12-2009 10:21 AM
You said you had a .lib file and in fact you have an llb file. There is a huge difference between an 'i' (eye) and an 'l' (ell).
There is a LabVIEW Instrument Driver Export Wizard but it is only for newer project style drivers and you would need LabVIEW. There is no other way to convert from a LabVIEW driver to a CVI driver. If the LabVIEW driver is using ActiveX properties and methods, you will have to write the same thing in CVI.
07-13-2009 06:43 AM
Thank you for your help.
It's indeed .LLD file. I'll try to do something with it.
