NI Home
Cart Cart | Help
You are here:
Reply
Active Participant
Andrew_E
Re: Voice recognition for control wheelchair
[ Edited ]
I would suggest not to use cRIO because you would basically need to reinvent the wheel and create a lot of the labview code already existing for similar applications. I would first do some research and search on NI.com for similar applications. I found one here. Then before you get started make sure you understand the fundamentals of what the code does and how to get started making measurements and desigining control systems. Finally, I noticed that the example I pointed to was using alot of Express VI's, it may be more intuitive if you didn't use express VI's, but rather taught yourself the basics of NI-DAQ when writing the code.
RIO Embedded Hardware PSE
CompactRIO Developers Guide
Member
moha62
Dear sir
Thank you for repplying me, and take time to find answer for me. I start to look at this topic and if I have problem, I will ask you again if it possible.
Best Regards,
Mohammad pasvar
Member
GreeceHellas
Re: Hello I Want Labview Control An Indicator By Voice Recognition
Hello mates. If anyone has achieved to do that I would be very thankfull to upload the VIs. I achieved to display some particular voice commands but I cant control any indicators with them.
Member
moha62
[ Edited ]
I still work on it, but I have to finished it by next week, so whenever I done it, I will put it here
Member
GreeceHellas
[ Edited ]
See if that can help you with that. I am trying to make it work. I want the indicators to work separately.
Member
moha62
thanx, but i tried already, u did not attach the speech recognizer.vi
Member
GreeceHellas
[ Edited ]
Check this now. It must be OK
Member
moha62
sure, I will try.
Thanx
Member
ithinkfrank
It still asks for Speech Recognizer.vi I am using LabVIEW 2010
Member
GreeceHellas
If i am right you have to delete the block with the question mark at the block diagram and wire it.
My Profile | Privacy | Legal | Contact NI © 2011 National Instruments Corporation. All rights reserved.    |    E-Mail this Page E-Mail this Page
