05-27-2011 01:24 PM - edited 05-27-2011 01:25 PM
I would suggest not to use cRIO because you would basically need to reinvent the wheel and create a lot of the labview code already existing for similar applications. I would first do some research and search on NI.com for similar applications. I found one here. Then before you get started make sure you understand the fundamentals of what the code does and how to get started making measurements and desigining control systems. Finally, I noticed that the example I pointed to was using alot of Express VI's, it may be more intuitive if you didn't use express VI's, but rather taught yourself the basics of NI-DAQ when writing the code.
05-27-2011 09:44 PM
Dear sir
Thank you for repplying me, and take time to find answer for me. I start to look at this topic and if I have problem, I will ask you again if it possible.
Best Regards,
Mohammad pasvar
06-12-2012 07:51 AM
Hello mates. If anyone has achieved to do that I would be very thankfull to upload the VIs. I achieved to display some particular voice commands but I cant control any indicators with them.
06-12-2012 08:14 AM - edited 06-12-2012 08:15 AM
I still work on it, but I have to finished it by next week, so whenever I done it, I will put it here
06-14-2012 05:04 AM - edited 06-14-2012 05:05 AM
See if that can help you with that. I am trying to make it work. I want the indicators to work separately.
06-14-2012 05:27 AM
thanx, but i tried already, u did not attach the speech recognizer.vi
06-14-2012 05:34 AM - edited 06-14-2012 05:35 AM
Check this now. It must be OK
06-14-2012 06:10 AM
sure, I will try.
Thanx
06-23-2012 08:08 AM
It still asks for Speech Recognizer.vi I am using LabVIEW 2010
06-28-2012 05:16 AM
If i am right you have to delete the block with the question mark at the block diagram and wire it.
My Profile | Privacy |
Legal |
Contact NI
E-Mail this Page
