07-25-2016 02:24 PM
Ok, I tried deleting that ini file. As far as I can tell it looks correct, and deleting it and restarting the controller results in a file that looks the same. It's attached.
I force reinstalled PXI platform services and MAX on my computer, and I reinstalled platform services on the controller.
07-25-2016 02:26 PM
I am trying to load waveform files from my computer onto the controller. Am I supposed to transfer the files separately to the controller first?
07-25-2016 02:27 PM
Sorry, load from the computer onto the function generator. I don't have the files saved on the controller. If that's what I am supposed to do, how do I reference files saved on the controller in Labview? It doesn't seem like that's how the examples work.
07-25-2016 02:33 PM
07-25-2016 03:14 PM
Ok, then I am indeed using the examples incorrectly. I thought that the point of the vi was to move files to the remote system. It looks like I can find the files through Labview code after moving them to the controller's hard drive.
MAX is still broken, but it sounds like it is pretty useless for this setup anyway.
07-25-2016 04:37 PM
The point is to deploy compiled LabVIEW code, not to copy files. To make future support easier, be sure to very explicitly mention the fact that you are using LabVIEW RealTime.
MAX is still broken
Broken how? Maybe we can help you with that as well. If what you mean is: The Soft Front Panel running on the Windows system does not control the device on the remote RT system, then you are right: this is a limitation of our Soft Front Panels.
07-25-2016 04:46 PM
I did mention above that I'm running this in a PXI chassis with a PXIe-8840 controller. If that's not clear enough, it's because I didn't realize that I have another option for how I control this system.
MAX is still behaving as I described above. The settings pages for the chassis and for every card in the chassis display the error: "NI MAX has experienced an internal error and cannot load the page." The controller gives a blank page.
