04-13-2015 04:39 PM
Hi!
I want to generate a digital signal (0-5V) in order to turn on and off an hydraulic pump. The time on (high) and time off (low) are specified by a MatLab code, so that once the pulse has finished one cycle, the program should be go again to MatLab code and take two times again. Then it should generate the signal again.
Thank you for the help.
Miguel
04-15-2015 09:18 AM
Hi Miguel,
Thanks for the post. I'm a bit confused as to what you're trying to do. Are you trying to output period of a waveform of 0 V and 5 V in your third party code, and then repeat the process twice? It seems like a simple application that you would be able to find many related examples for in www.ni.com/examples. I'd recommend doing a basic search there for your application, and using one of those examples as a template.
04-15-2015 06:20 PM - edited 04-15-2015 06:20 PM
Thanks for the reply.
I have a system with an hydraulic pump, power supply, transistor and computer. I would like to send a digital pulse from my computer (0-5V) to the transistor. The transistor then closes a circuit (power supply and pump), and the pump starts running.
Then, I would like that each sample (each pulse) has specific width (time on), and also specific time off before it starts with other sample. These times (time on and time off) are computed by a MatLab code.
I'm working with DAQmx drivers and I also have a BNC 2110.
I also attach my code in Labview that I am trying to modify.
Thanks a lot.
Miguel
04-16-2015 01:19 PM
Hi Miguel,
Thank you for clarifying, and sending the VI. I believe you'd want to work with a digital start trigger, and then continously output digital waveform data until you reach a certain point. The following community example provides this functionality. It also allows you to specify a specific duty cycle, meaning you could specify a specific time-on width.
Counter - Continous Output
https://decibel.ni.com/content/docs/DOC-25157'
If you would like to use a Matchsript node to acquire data, the following article gives an introduction to data acquisition with Mathscript
Using the MathScript Node to Acquire Data in LabVIEW
http://digital.ni.com/public.nsf/allkb/F65D9ADF86FF1724862572D7005AA4A1
04-16-2015 02:47 PM
Thanks a lot for the information Andy.
I'am gonna check the example that you provided me. It seems that it can work for my system.
If I get the code, I am gonna upload it and may be can serve as example for other people!
Thanks again.
Miguel
04-17-2015 09:48 AM
Great, glad to be of assistance, thanks Miguel!
