02-14-2008 12:42 AM
02-14-2008 03:32 PM
Hi madd,
You can create something similar to a constellation plot by wiring your data into an XY Graph or Waveform Graph or Chart. Then right click on the graph or chart and select Properties. Go to the Plots tab and change the line type to None.
02-16-2008 10:01 AM - edited 02-16-2008 10:02 AM
02-13-2017 10:56 AM
Hello
I am trying to make a program for 8 PSK Modulation but not able to make it. Can you please help me with the program for 8 PSK modulation.
Harsh
02-14-2017 09:37 AM
Hi Harsh,
You are going to want to use the Modulation Toolkit. This is not strictly necessary, you can always develop the modulation on your own, but it makes it much easier. You may already have the Modulation Toolkit on your computer, it comes with the RF Device Drivers.
You may also have more luck posting in the RF Measurement Devices Forum.
Cheers,
Michael
02-14-2017 09:39 AM
And if you want to know what VI you should use for PSK, MT Modulate PSK and MT Demodulate PSK will help.
