09-29-2009 12:46 PM
Solved! Go to Solution.
09-29-2009 01:32 PM
Hi anaddaff,
If soft front panel is functioning properly I will assume
you have the appropriate version of NI-Fgen installed, 2.6 or later is
required. The device driver vis can be found in the following location:
As well as LabVIEW examples here: C:\Program Files\National
Instruments\LabVIEW XX\examples\instr\niFgen.
I hope this is helpful please post back with any further
questions. If the Vis are missing from these two locations you may need to
reinstall NI-Fgen ensuring that LabVIEW support is selected to be installed.
09-29-2009 02:27 PM
09-29-2009 02:36 PM
Yes, installing the driver before LabVIEW has everthing to do with your problem.
If you are going to use IVI, you will have to create a locgical name for each instrument you have.
