06-26-2014 01:44 AM
To
Kyle_A
Hi Kyle_A,
Iam using PXIe-5451 signalgenerator, when the Underflow occurs in Endpoint FIFO the Active LED on the module gets Red and it doesn't effect my application(means FGEN still aquiring the samples from endpoint FIFO).
Can we continue to use the module when it is in this condition ? or shall we have to stop the application ?
07-10-2014 01:43 AM
Iam using PXIe-5451 signalgenerator, When the Endpoint FIFO underflow Occurs in the Active LED on the module gets red and it does not effect my application (means FGEN still aquiring samples from the endpoint FIFO).
Reference example FGEN P2P basic.vi from ni examples.
Can we proceed to use the module When it is in this condition? or shall we have to stop the application?
