Generally, windows sound devices can record at one of the following settings: 8000, 11025,22050,44100 Hz. This value is generally set in the sound properties of the sound card. You can then save your input as a wave file (*.wav). LabVIEW FDS comes with a set of sound VIs that can process a wave file and save it in ASCII format for analysis. It is essential that you know the acquisition rate in order to perform frequency analysis. If you use the Sound VI Tools, you can "interogate" the *.wav file and determine the sampling rate of the sound track.
