03-25-2015 06:50 PM
I have acquired some data(Magnitude versus frequency), I want to just select the points which are in specific range(their frequency.....X-axis), for example I want to filter the signal only for the points which are between 20Hz and 30Hz. Does anybody know how can I do that?
I used "In range and coerce", but it gives the "lower limit" for the points which are not in the rang. I don't want it to pick that points.
I'd appreaciate it.
Petar
Solved! Go to Solution.
03-26-2015 11:26 AM
I think you could try using a For Loop instead of the "In Range and Coerce" function. You just input your data into the For Loop, and using a conditional tunnel you can compare the data that you want. I attached a picture of a little example I created for you to see.
03-26-2015 03:07 PM
Thanks so much, It was really helpful.
Petar
03-26-2015 03:44 PM
You are welcome!
03-28-2015 02:53 PM
