Is this related to a support problem you are having? We normally do not document component values unless it's necessary in order to use the board. (This helps prevent someone else from being able to manufacture our boards themselves.)
Maybe the board just needs to be repaired? Perhaps if you could explain more about the problem you're having, I could be of more help.
Russell McMurtrey
http://www.ni.com/support
