sir,
thank you very much for quick reply.But, unfortunately the problem is not yet solved.
I have made the CJC as built-in type , but still I could not get the proper result by running the test panel in MAX .This time I have attached an word-file describing in details about the configuration I made in MAX.
1.My card specification is PCI-6071E
2.chasis:SCXI-1001
3.module:SCXI-1102
4.Terminal Block:SCXI-1303
sorry due to some technical problem i could not attached the file .so, let me describe about the configuration in details
analog input cofiguration-
1.physical quantity:Deg.C.,range:0-100
snsor:k-thermocouple
device:Dev1_SC1_MD1:SCXI-1102
channel:0
CJC Source:built-in
2.device & interfaces
a)PCI-6071E(Device1)
properties:
AI:polarity
/range:-10.00v to +10.00v
mode:differential
AO:bipolar
acessory:none
OPC:disabled
b)SCXI:1001
module:SCXI 1102 has the following properties
general:
connected to:PCI 6071E
operating mode:multiplexed
channel:
channel:0
gain:100
acessory:SCXI-1303
thanking you
indrajit talukdar
IIT, Guwahati
Assam, India
