The board can only be configured for one scan rate per task ID. Apart from generating two task IDs and switching between them (very complicated and not highly recommended), the easiest soultion is to scan all the channels at 1000 samples/sec. For those channels you want to scan at the lower rate, you can either store every tenth point, or if you have sufficient processing speed, you can average every ten points and save that value.
