Hello Guys,
I am Preetam
Here i am trying with the Parallel Operation of SCXI-1520 and i am facing some problems regarding this.
I am using the SCXI-1000 Chassis,SCXI-1349, SCXI-1520, SCXI-1314 and PCI-6023E DAQ card.
I connected two 1.5V battories to SCXI-1314( Ch0 and Ch1) and connected it to SCXI-1520.
First I tried to configure SCXI-1520 in Multiplexed mode(Using SH-6868 cable and SCXI-1349 Connector). I set the properties of SCXI-1520(Gain as 1, Bridge Configuration as Full Bridge). When i acquired in multiplexed mode, it is showing the Voltage(battory Voltage) value as 1.5
Then i removed the SCXI-1349 and Connected the 50 pin Cable((50 pin female connector)to the back plane of SCXI-1520.
When i checked the Voltage at the Channel 0(Ch0+ and Ch0-), it is coming around 13V.
The properties set in the multiplexed mode, doesn't remain same if you disconnect the Chassis from DAQ card? If 1.5 V is coming in multiplexed mode, why it is not coming at the Channel 0 at the Backplane?
While i am connecting the siganls from Backplane to the DAQ device, are there any signals which siganls I should Connect to the DAQ card apart from Ch0 to Ch7?
How should i achieve this parallel mode operation?
Please let me know the complte colution in detail....
