The register level programming would need to occur on both the E-Series device and your custom module. Since the E-Series board is controlling your chassis, you would need to program some registers on the E-series device to initiate communication with your custom module, then you would need to have registers on your module which would allow certain action such as selecting a particular channel or setting a specific gain. We neither support the register-level programming of the E Series board nor the register level programming of your custom module. This is why it is usually best to make an 8 channel parallel module that is transparent to the chassis, yet conditions your signals to your liking and then ca
scades them into a multiplexed module, such as the SCXI-1140, using the SCXI-1346 adapter cable.
Bill B
