currently, i made a temperature task and added my voltage channels to it with a "DAQmx Create Task.vi"
this all works fine and dandy. however, when i try to add a frequency input to another instance of "DAQmx Create Task.vi" or wire it instead of either voltage or temperature, i get an error:
Error -200559 occurred at DAQmx Create Task.vi
Possible reason(s):
Task cannot contain a channel with the specified channel type, because the task already contains channels with a different channel type.
Create one task for each channel type.
if i create a seperate task for my frequency reading, there is no way i can measure it along with my other readings... labview 6.1 never had this problem. unless im missi
ng something here, it seems like this is a step down from the previous version when labview didnt seem to care what kinds of signals you were measuring at the same time.
