NI Home
Cart Cart | Help
Hello Events Academic NI Developer Zone Support Solutions Products & Services Contact NI MyNI
You are here:
NI Home > NI Developer Zone > NI Discussion Forums
Reply
Member
mhs1000
few questions about Earthing?
Hi all,
I have some basic questions about earthing. Please anyone explain them and provide any reference material also.
Q1. In Industries there are normally two types of earth, one is "Instrument Earth" and other is "Protective Earth". what is the difference between these two?
Q2 what is the difference between AC and DC earthing?
Any help will be appreciated.
Active Participant
Henrik_Volkers
Re: few questions about Earthing?
To Q1:
Both are connected at one point , however the PE can (and will) carry more noise due to currents (up to 30mA or even 300mA depending one the installed RCD, in some cases even higher ) from line filters in switched power converters , C&L coupling to the line power etc..
While the PE is build (and tested! ) for low resistance  the impedance (here inductivity) can be quite high, so RF content is not well grounded.
So a instrument earth as an separated path is build up, but not with the intend to carry lot of current, just to establish a clean ground potential.
To Q2:  A capacitor to ground will be low impedance for high frequency (Z=1/(j*2*pi*f*C)) but not for DC . On the other hand an inductivity is a good conductor for DC , but not for AC (Z=j*2*pi*f*L).
Depending on the task you have, you can decide what part you tide to ground.
Greetings from Germany
Henrik
LV since v3.1
Active Participant
Buechsenschuetz
Hendrik (almost) said it all. A PE terminal should not be used as return path or GND terminal for signals. Its main purpose is to supply a connection between the device housing and the earth line of the mains power supply.
Sometimes it is necessary to make a connection between the signal return path and the GND or earth terminal, e.g. in case there are EMI problems. In this case sometimes it helps to connect the signal return path or signal GND with a (rather small) capacitor to the earth terminal.
By using this web site, you accept the Terms of Use for this web site. Please read these Terms of Use carefully before using any part of this site. Please go here for information on ni.com's copyright infringement policy.
My Profile | Privacy | Legal | Contact NI © 2011 National Instruments Corporation. All rights reserved.    |    E-Mail this Page E-Mail this Page
