11-08-2006 06:03 PM
11-09-2006 06:20 PM
04-14-2015 07:33 PM
Hello
I need some guidance and suggestion for my work.
Firstly, I am pretty new with lab view and DAQ system. Somehow, I am studying the data avaialble at NI websites to understand LAB View, DAQ & Strain gauges and have couple of questions.
I have a specimen which has to be tested for compression load. The specimen is installed with minimum 4 and may be 6 strain gauges.
I need to make a circuit to measure strain individually for these 6 different gauges and need to acquire the data using NI- DAQ max (PXI-1042) system.
I am kind a confuse to understand how many wheat stone bridge circuit do i need to have to measure strain from these 6 different gauges.
Will these circuit be quarterbridge or half bridge or fullbridge to measure strain at 6 different locations?
I will appreciate your input.
Please suggest.
Ankush
04-15-2015 09:30 AM
Hello Ankush,
That project was back in 2006. I don't remember to much about it. Would need to start diging though notes.
I have a Compaque DAQ card set up, which is very easy to use with strain guages. Lab view code also provides an option for selecting half or full bridge. I belive your type of strain guage will dictacte which you choose.
you can contact me directly at alfonso.lopez@hexcel.com if you need to.
good luck.
04-16-2015 01:54 AM
Hello Lopez.
Thanks a lot for your help.
I am still trying to figure it out. i am thinking to make 4 quarter bridge for 4 strain gauges on a breadboard and connecting to Ni-DAq system.
I may need your help for lab view program. I would write you a mail.
Ankush
