08-06-2013 08:41 AM
i'm constructing a differential thermal analyser.I have the readings in volts from the reference junction connected to a
08-07-2013 05:40 AM
What type of temperature sensors are used ?
For common thermocouples you would need some µV resolution.
If you have your setup running fine with the indicated display values , and you only need to read it into the PC: USB to RS232 converter are cheap...
08-07-2013 06:23 AM
A thermocouple sensor generates a (small) voltage, however, to measure temperature you need a cold-junction compensation circuit which usually is not integrated in standard DAQ systems. Anyhow, a resolution of 1mV is not sufficient for thermocouple measurement. It would be helpful if you would indicate which type of sensor you are going to use.
To expand RS232 ports on your computer, there are simple USB devices with additional RS232 ports.
08-07-2013 10:58 AM
08-08-2013 01:45 AM
OK, it seems as if you everything you need to get a suitable voltage reading.
If you have a desktop PC you can use an additional interface card giving you 2 or even more serial ports.
If you have a laptop/notebook you should use an USB adaptor with serial port(s). Once installed, these "look" like a serial port to the operating system and can be used as such.
It is NOT possible to connect more than one device to one serial port, there are no splitters or multiplexers. RS232 is a true point-to-point interface not suitable for connecting several devices to one port.
08-08-2013 06:22 AM
and some more stumbling blocks:
Check if the voltage module really have RS232 output ... sometimes they have a rs232 protocoll but ttl level output 3V or 5V , sometimes inverted 😮
some of these modules run mad if one sense input and digital output share the same ground .. BTDT
08-08-2013 09:49 AM
The output of the digital indicators are RS 232 male pins(9 pins). To one of the Digital indicators I guess I can connect a RS 232 male pin to female pin cable for feeding Delta T into the com1 port of my computer [I have only one com port on my CPU]. Since I dont have another com2 port on my PC to transfer the small voltage readings from a cold junction compensation amplifier i shall use a USB to Serial (RS-232) Adapter connected to another digital indicator, and the USB to the USB port of my CPU. Is my understanding right?????? HELP
08-08-2013 03:10 PM - edited 08-08-2013 03:11 PM
yes, that should work...
start with one port and one meter for testing.
