Signal Conditioning
can NI DAQ USB 6008 handle high frequency about 100KHz??
I have a project about Ultrasonik Testing..
my frequency is 40KHz..
and I will sampling the data >80KHz
can NI DAQ USB  6008 handle high frequency about 80-800KHz??
Message 1 of 9
(4,928 Views)
Why haven't you looked at the product page, the manual, or the specifications?
http://sine.ni.com/nips/cds/view/p/lang/en/nid/201986
Message 2 of 9
(4,927 Views)
I have seen it..
In Counter, It said that Maximum input frequency is 5MHz..
does it mean that it can handle frequency in kilos and I can use ADC to process the signal with it?
Message 3 of 9
(4,922 Views)
sorry, I'm asian from Indonesian..
and Im beginner..
Im still doesn't know about the spesification in the datasheet..
Message 4 of 9
(4,920 Views)
It's strictly an event counter for ttl signals and does not have any sort of adc. No accurate method of determining the frequency even if you do have a ttl signal.
Message 5 of 9
(4,918 Views)
so, can you suggest me some advice to solve my problem?
I have to process the signal 40 KHz into spectrum with A-scan representation in labview..
what should i do ?
im so confused with the hardware and software..
Message 6 of 9
(4,910 Views)
The Nyquist theorem is the fundamental basis for all sampled data systems. It states (as you a ppear to be aware) that to accurately reproduce a continuous signal from the sampled representation the sampling rate must be greater than twice the bandwidth of the signal.
To process a signal with a 40 kHz bandwidth requires sampling at greater than 80 kHz.  The USB-6008 has a sampling rate of 10 kHz for one channel. So, it cannot acquire the data you need.
You need to obtain a DAQ device which has a much faster sampling rate. If your ultrasonic signal is pulsed or swept in frequency, the bandiwdth of the modulation must also be considered. I would look for  a DAQ device which could sample at least 100 kHz and possibly even faster.
Lynn
Message 7 of 9
(4,903 Views)
okay..
what's the type of device can handle 100KHz?
I'm waiting your advice...
Message 8 of 9
(4,885 Views)
http://www.ni.com/data-acquisition/multifunction/
Call your local Sales Engineer for help.
Message 9 of 9
(4,875 Views)
