Signal Conditioning
Write waveform data to a text file
I'm having difficulty writing waveform data to a text file.  I'm using the strain gauge example provided with LabView and I just need to write the data to a file.
please help?
(6,693 Views)
Hi Blue_Estel,
You could use the Export Waveforms to Spreadsheet File function if you need to write your waveform data to a text file.  You could also look into the Write to Measurement File Express VI, which provides a graphical interface to configure how to write your data.  Be sure to post back if you run into any issues while implementing these functions.
Thanks for posting and have a great day!
-John
John Passiak
(6,665 Views)
Thanks, I'll give it a try.
~chris
(6,659 Views)
i am doing the project on heartrate monitoring system through internet (tdms) and when i try to save the data it only saves this data to ,txt format please help me how to store ecg waveform to measurement file
(5,425 Views)
is there any means to send waveform data using smtp
(5,424 Views)
Hello Blue_Estel,
This links could also guide you in a good direction:
"Moving Data From LabVIEW Into Excel"
http://www.ni.com/newsletter/51339/en/
"Writing TDM and TDMS Files in LabVIEW"
 http://www.ni.com/white-paper/9334/en/
Daniel Cabezas
Applications Engineering
www.ni.com/support
(5,387 Views)
