03-09-2009 08:59 AM
I'm having difficulty writing waveform data to a text file. I'm using the strain gauge example provided with LabView and I just need to write the data to a file.
please help?
03-10-2009 10:27 AM
Hi Blue_Estel,
You could use the Export Waveforms to Spreadsheet File function if you need to write your waveform data to a text file. You could also look into the Write to Measurement File Express VI, which provides a graphical interface to configure how to write your data. Be sure to post back if you run into any issues while implementing these functions.
Thanks for posting and have a great day!
-John
03-10-2009 03:42 PM
Thanks, I'll give it a try.
~chris
05-30-2014 05:09 PM
i am doing the project on heartrate monitoring system through internet (tdms) and when i try to save the data it only saves this data to ,txt format please help me how to store ecg waveform to measurement file
05-30-2014 05:14 PM
is there any means to send waveform data using smtp
06-02-2014 09:10 AM
Hello Blue_Estel,
This links could also guide you in a good direction:
http://www.ni.com/newsletter/51339/en/
http://www.ni.com/white-paper/9334/en/
Daniel Cabezas
Applications Engineering
