I am using an SCXI 1000 chassis and the SCXI 1200 board. I am trying to debug some software and cannot seem to get a digital output to change state. When I run the MAX software while monitoring Port 0 bit 6, this bit will go high. If I shut down the software the bit goes back low again. If I go into the test panel and try to change it, I get error 10613. Also, if I run my program, as soon as it initializes the chassis, the line goes high. When I get to the piece of code to set it low, as I step through it it does not change state. Is there a configuration somewhere that I have missed? Is there a way to debug the hardware first? Sorry for all the questions, but I am just beginning to l
earn about Labview/CVI.
Thanks for any and all help!
Barry Gebhart
barry_gebhart@trimble.com 937-245-5156
