We currently provide a 5v supply that we switch with a 1163R. I want to know if there is a SCXI module that would provide a TTL signal right to our solid state relay instead. thanks
One option would be to use the SCXI-1163. It is an optically isolated TTL output module. It does require a +5 VDC supply voltage, but, if you do not require isolation, your DAQ device can provide this required voltage. Below, I have included links to the product page for the SCXI-1163 and a KnowledgeBase discussing the configuration I just mentioned:
