Signal Conditioning
What do I need to perform temperature measurement?
I have a 16-channel DAQ Card installed on my laptop. I want to measure temperature at 6 points in a system, along with pressure and flow. I have already written a 16-channel data aq. VI, and tested the pressure transducers and flow meters. What equipment do I need to complete my system, using my exisitng 16-channel DAQ card? 10 channels are being used by other equipment; 6 are reserved for temperature. Do I need some sort of signal conditioning for the Type K thermocouples I am using? Thanks.
(2,782 Views)
Mikehuh,
On our website he have a utility that will walk you through designing a Data Acquisition and Signal Conditioning system specific to the needs of your signal. Just go to http://amp.ni.com/dd/jsp/ddconfig.jsp and enter in the appropriate information. Good luck with your application!"
(2,782 Views)
