I'm scanning 25 channels on a SCIX-1100. Setup for differential input, connected to my MIO board. When I run the scan, the first inputs should be 0, but I'm getting non-zero numbers.
They start high, and disappear in a few channels. If I change the sample period, the second and third values drop, but the first remains (but slightly reduced).
If I use the calibrate function, I can ground the PGIA for a delayed time, it helps but doesn't take the whole value away.
I found that if I scan the module twice (in the same scan operation), it seems to not have the problem.
Any ideas? Chassis problem? Software? Module?
