Actually, the Test Panel for the MIO board will work with SCXI. All you need to do is type the scxi channel call (ASCII format - ob0!sc(m)!md(n)!ch:ch ) in the channel reference field. You can look at mutiple channels on the SCXI bus and the Test Panel Utility will display all of the referenced channels using different colors. You will not be able to read a current signal; however, if you know the resistance of the sensor, you can calculate the current from the voltage reading.
