Signal Conditioning
Thrust Modulation for rockets
To whom it may concern,
I am currently flying rocket's to see the effect of thrust modulation by moving a steel puck up and down to control thrust.  This puck is moved up and down by a servo which is operated by a  a self contained PWM signal I made in labview.  I then turned this VI into a RT application for a myrio.  The PWM signal is controled through a self made PID which prior to that is made by comparing onboard accleration of an acclerometer with a Upon ddoing this i flew the rocket today but upon checking the onboard data on board after flight(I used ignal express)  all my files were zero. I was saving the PWM SIGNAL, system error, and onboard accleration.
Obviously on a rocket flying up does not result in zero, so can someone please tell me what i'm doing wrong, is the code wrong or am I saving wrong?  I've attached the following VI and below show's picture of the code I made.  Any help is greatly appriciated as rocket motor's aren't they cheap and I hope to fly tuesday.
(5,283 Views)
Does the application log data correctly when run in interactive mode?  Do you other Write to Measurement File VIs work as expected?
I also noticed that the top loop has no wait in it which may cause it to log repetitve data very quickly.  Can you add a wait or place the Write to Measurement Files into another one of the already existing loops?
(5,262 Views)
The strain gauges I had saved, saved correctly half way then went to a back up file system, which is another issue i'm trying to peice together.
(5,259 Views)
I think it would be beneficial to reduce the number of files being generated and possibly simplify the writing process.
(5,243 Views)
