I'm using a AMUX-64T to multiplex voltage signal from thermocouples connected. The AMUX-64T deliver any signals to my DAQ card, AT-MIO-16-E. For the other side of thermocouples, they are directly and permanently attached to bare conductor which is short-circuited loop and holds at least 200 A AC-current or zero in cycle. I found that every temperature value showing on my monitor was strange data. It change all time. When I compare the temperatures on my monitor with on a digital multimeter, the difference is about at least 20 degree celsius. I would like to know how I should set any jumpers on AMUX-64T and what point of system should be connected to ground. Should I use single-end or differential signal?
How I use it?
