NI Home
Cart Cart | Help
You are here:
Reply
Donners
Re: Saving PSD to TDMS
Hi Laurence,
I'm getting a cluster of 3 elements. I don't know how you are getting an array of clusters. Both PSD vi's are giving me the same.
Donners
Larry.C
Hi Donners,
The only reason I got an array of clusters was because I fed the PSD function with an array of waveform data. The reason I did this was because I believe you stated before that you had the same thing (I may be wrong). You could just get rid of the FOR loop and it should work, writing to file.
Kind Regards,
Laurence C.
Applications Engineer
Donners
Cheers Laurence
Donners
Donners
Hi Laurance,
I just realised when I compared the saved graph in the TDMS file to the displayed graph from the front panel. The frequency is scaled some way. The saved frequency spectrum is showing the same shape but at a higher value. The one on the right is the data saved in the TDMS file, the other one is plotted directly from the PSD vi.
Donners
